LadyJessie
This is a question following from the 'genset' thread below, but it really opens up another issue so I think it warrants a different thread:
One of the problems of 'liveaboardness' is that it is often extremely difficult to chase up warranty commitments and you can be left high and dry. The experience related on the 'genset' thread below by Englander and myself of seemingly the same genset with the same sort of problems, but a very different result is very typical of this problem.
When I finally understood what the problem really was with my genset (very well described by Englander on that thread), I was in the Caribbean. Something like 4000 nm's away from the installer and the manufacturer. They both pointed fingers at each other and I was too far away to get them into a room and 'bang heads together' to resolve this issue. I had to make new repairs by 'non-FP' authorised repairshops (not a lot of those in the Carib) just to get going. Then when I returned to the Med to revisit this issue, I found that the local FP 'authorised representatives' actually knows less about this genset than I now do from having to fix it continuously. By now FP disowns any responsibility because 'warranty repairs' have been performed by 'non-authorised' persons. Well, doh. That is what happens on a cruising yacht in remote places; you do not wait for the FP repairman to helicopter in, as if they would..... You try to solve the problem.
In summary, there is a serious issue with manufacturer's responsibility that they can easily muddle for liveaboards cruising the world. The only solution I can think about is tough testing of all equipment onboard before you set off, but it is often difficult to always simulate liveaboard conditions.
This is partially a 'beware' thread for new 'would-be-liveaboards' and a question for present liveaboards: how do you deal with long distance warranty and 'fit-for-purpose' claims?
