tobble
how to do this?
I want to apply an equalisation charge to my batteries, two 110 ish Ah wet lead acid, Rolls brand. they are about a year old, and have been discharged a bit too low on two or three occasions - low enough to notice tungsten bulbs are slightly dimmed (I didn't measure the voltage, silly me). There is a bit of discrepancy between the SG readings, last time I checked it was a range of two or three 1/100ths
a) How best to achive the desired voltage - I have a sterling alternator controler type charger, thought I could temporarily add a diode between the voltage sensing wire and the battery +ve, so the controller boosts the voltage by 1.2 V - If I recall correctly this would mean it would give 14.8V plus the 1.2 so 16V. If this isn't appropriate, any other ideas that don't involve serious outlay?
b) How long should an equalisation charge last for this size bank?
c) are there any other tips on the proceedure? I'm guessing it'd be best to make sure the batteries are fully charged first? presumeably make sure they are topped up so the off-gassing doesn't present serious issues... don't lick the teminals... anyhting else?!
cheers in advance...
