Epoxy with pigment
Tradewinds
12 Jan 2003
Suffolk
www.laurelberrystudio.com
I know standard clear epoxy resin doesn't like UV and tends to go brown.
What happens if it's pigmented? For instance, if I was to use a compatible white pigment would it go yellowish over time? Same with a light grey or similar.
Not life or death, but I would be interested to hear from those in the know.
Ta.
I have pigmented epoxy filler cream and black to create stripes in teak veneered flooring. Not exposed them enough to tell whether it reduces UV effects.
I glassed a rudder with epoxy and covered the rudder in white pigmented sp epoxy , after two years it had gone cream on the surface so I covered it in good primer and two pack white paint, that last until I sold the boat two years ago.
I would be reluctant to use pigment if the work was structural. I have though used some pigment in epoxy when filling to give some more depth to the paint colour.
Nothing structural, just cosmetic.
Thanks for the other answers.
I know you can use West epoxy pigmented with graphite (or some such) to create a faux black caulk effect for decking - but it's white & very light pigments I'm curious about.
I've used an epoxy putty product in the cockpit called Marine-Tex in my cockpit which has stayed white & not degraded in over 15 years - but that doesn't seem to be available in the UK.
Wonder if oldsaltoz is around to comment?
