yachtorion
I got sick of buying ludicrously expensive small pots of mixed filler for doing GRP work, so decided to try making my own.
I've got MAS non-blush epoxy resin with fast hardener, mixing pots, lollipop sticks, colloidial silica, microbeads (above W/L), glass bubbles (below) and epoxy pigment. The up-front cost is quite high, a few tubes of plastic padding, but what I've discovered is that a little of each goes a really long way - lots of tubes of plastic padding.
You get a lot of glass bubbles for not a lot of money, they are mostly air after all... and once you add them to a little bit of resin it seems to at least double the volume of the original resin (I mix the resin and hardener first as i've got a good pot life).
Resin, add beads.... Stir a lot... add silica... stir more.. add silica... until you get the consistency you want for the job at hand (do that with pre-mix filler)... then add some pigment and stir well again.
The resulting filler is just brilliant. Sands easily. Spreads easily. And you don't run out because there is a load of the raw material and you just mix some more.
The manufacturers give weights of how much of X to add too how much Y resin, but to be honest it's pretty easy to judge by hand.
For many on here I'm sure this is all really old news.... but if you are sick of little tubs of plastic padding etc hanging around and costing a fortune... it's really worth giving this a try! It's so easy and the results are actually better than the pre-mix fillers because you can vary the consistency.
Do wear a mask though. Until well mixed in those microbeads fly everywhere.
