rogerthebodger
I have a McMurdo EPIRB which will need the batteries to be replaces. I have opened the unit and found 3 D type tagged batteries and found RS have there which seem to be the same.
The volatage of the current batteries are 3 volts but the RS ones are 3.6 so should be OK. Any one know if these are in fact OK.
The EPIRB has a test button, does any one know if this tests by sending a signal to the satellite and maybe to MCA whith a return to confirm total end to end transmission. If not can the end to end transmission be tested by arrangment.
My question is as a result of the loss of Moquini when the EPIRB send only one signal message then stopped so I would like to be able to completley test the end to end messaging so confirming receipt of message
