Reptile Smile
In some ways it was very pleasant to spend the afternoon on the 'new' Hurley 20. I had a bilge pump to fit, and it was rather nice to be tucked up inside with the heater on and hoolie blowing outside...
On the other hand...
I'd left the wiring diagram for the cheapie all-in-one bilge pump, and the three way switch at home. Even do, I didn't think it would be beyond the wit of man to work out which way was up. Unfortunately, it was.
Couldn't get anything out of the bilge pump at all. Thinking it was faulty, I unplugged it, and connected it straight to the switch/negative bus. Nothing. In the end, out of desperation, I touched the ends to the massive starter-motor style cables that bring the battery power to the cabin and it turned fine.
This obviously limited the number of things it could be. Tracing it back from here, however, got even more confusing. The choc block bus bar was obviously rubbish, so I disconnected this, and took the 1 foot wire that closed the bus bar loop to the massive cable straight to the bilge pump. Still nothing. To clarify, it worked from the massive cable, but not from the end of the 1 foot cable connected to it. My multimeter said 12.68 volts from the massive cables, and 11.70 from the end of the 1 foot cable.
I suppose it retrospect I should have measured the current, not the voltage. Even so - I'd have expected the bilge pump to turn over on 11.7 volts..?
I also couldn't get *anything* else to work. No lights, nothing - I suspect because of the crappy common earth. The answer may well be to rip everything out and start again, though it don't know what gauge cables to use for what? And given even going back to barebones didn't work, I'm a little stumped. Any ideas..?
