stefan_r
- Joined
- 16 May 2001
- Messages
- 753
- Location
- Southampton & Greece (Chios)
I have recently had my MAN engines rebuilt as my revs were down and they were both smoking more than I would have liked.
Rebuild is completed with several problems found including valves and seats caked with crap and fuel injection pump timing out.
Everything now assembled and tested, stuff tightened and run for a few hours to run them in.
The largest underlying problem, however, is still there in that I am not achieving my book rpm - and previously achieved (some years ago) 2,300rpm.
It is not a problem with throttle movement - without load they will rev to 2,600...but with load 1,850 port and 2,000 starboard. RPM gauges checked and accurate.
Good news is the smoke has cleared...except from a bit of grey from the port engine...and that is clearing with each run so suspect a slight overfill of oil perhaps.
The engines are NOT smoking black (too much fuel) at any revs.
So, the big question - what's my rev problem?
I say the props are not sized correctly but at a couple of grand a throw it is a big gamble to take to find out it is something else.
Most cruising gear removed, spare fuel tanks (1,500 litres) emptied and running on 1/4 water and 1/2 fuel with 2 people.
Vital statistics:
Mochi 46 flybridge
Displacement unknown...going to calculate on haul out
LOA 46'9" / 14.25m
Beam 14'8" / 4.47m
LWL can't remember...have to wait for haul out
Engines: MAN D2848LXE rated 680hp each
Gearbox: Twin Disc MG5111 ratio 1.50:1
Running through Vee drives (no gearing)
60mm shafts
4 blade 26" props...unknown pitch...trying to find a man locally who can tell me.
Has anyone had experience re-propping?
Any decent shops out there?
One further problem - boat is now in Greece...so this is a bit of a one off and sending them back and forth to Steel Developments or whoever is a no-no. I don't mind buying them in the UK but on the basis they will be "right first time".
Cheers
Stef
Vital statistics:
Mochi 46 flybridge
LOA 46'9" / 14.25m
Beam 14'8" / 4.47m
60mm shafts
Cheers
Stef
