Strikeliner
I wonder if anyone can help? Whilst driving my Mercruiser 5.0l powered boat ( Maxum) recently the audible engine alarm sounded. I had been travelling for about 10 minutes or so at about 3200rpm. I immediately stopped and checked all the dials. They all showed perfectly correct readings and the alarm stopped. I decided to continue for a while at about the same speed and noticed that after a while the temp guage moved from a normal reading towards the left hand side of the dial i.e indicating a lower temperature. A reduction in revs very quickly caused the guage to move back to the normal reading!!!!!??????
The engine performance seemed fine. Oil level and gear lube levels are correct and there was no other apparent problem apart from the engine alarm sounding. Could this be a faulty guage or sender causing a duff reading and consequent alarm? The engine has run for less than 100 hours and works fine in every way. If anyone has experienced this or similar Iwould be pleased to hear.
Steve
Steve
