Engine Valve Openings
alec
16 Sep 2003
East Coast
My single cylinder diesel does not have glow plugs. It does however have the facility for an extra splash of diesel. I am not sure what this does to help cold starting though I do think it helps. It starts very easily in the summer.
In this recent cold weather I have found that a hair dryer aimed down the air intake for about five minutes also helps greatly.
My question is :-
Would it help if the inlet valve was open while I use the hairdryer to warm up the cylinder and how can I tell when it is open ? I can turn the engine over with my hands on the pulleys/belt. I can certainly feel the compression but get confused what to do next. I seem to remember something about different camshaft/crankshaft speeds and overlapping valve timings etc.
Thanks in advance.
If you can feel when it reaches the top of the compression stroke then the induction stroke starts one full revolution from there. At some point during the following half a revolution the inlet valve will open fully.
So warm things up first and continue blowing hot air in while turning it slowly through that half a rev.
That is my attempt to answer your question but I have no idea whether it will help.
sounds like you have low compression ! perhaps a straightforwards ring change will help and not break the bank
I had a hillman imp years ago, the only way to get it started was to pour a kettle of water over the manifold lol
mick
That brings back memories of a Ford Anglia with low compression - a common fault! I used to grill the spark plugs alongside my toast and she'd go first time. Happily, the body collapsed soon after, solving the problem of a permanent cure.
Whatever you do, I would advise against trying any of the starter sprays - they are so explosive they can knock out bearings. If your technique for priming is as per book, then the engine should start. I'm running a Sole Mini14 - 20 year old, Mitsubishi based and I don't believe for a moment that the glow plugs still work. Maybe I should fit new ones? In cold weather, about ten seconds cranking gets her going (albeit on full throttle).
Rob.
