Engine trouble
Ctlangford
New Member
16 May 2020
Hi. I have a mariner 115ho 2017. Starts first time every time, but when getting in the plane about 4000rpm the engine seems to bog down, loses power and the revs jump around. Only happens at high revs. Any suggestions much appreciated
Cheers
Check/replace fuel line, priming bulb and fuel filter from tank to engine. I had a similar issue on a Honda 75hp and it turned out my priming bulb was perished. It was loosing power at high revs. The filter/separator was fine so ran new fuel line and bulb back to engine and running 100% since.
probably max!
where are you based?
you should carry a spare pre filter and know how to change it. Could get you home if it blocks at sea.
perhaps get the engineer to show you.
probably max!
Hi C, as Farsco has implied, it is a really good idea to get to know the basics of your engine/boat systems functionality for your own and your crews safety and confidence into the future.
With outboards it will mostly be fuel or battery/electrical issues, cheers
Many thanks. I will sort it this week and keep you posted
