Paul&Ness
Hi Guy's, seeking some help relating to a problem I have with my engine temp alarms connected to Cummins 6BTA 300hp. I have already searched through older posts and nothing found. So my problem is that the Alarm sounds as soon as the ignition is turned on and the engines cold. Both the Alarm buzzer sounds and the warning light is on at the lower helm and upper helm position. Disconnecting the leads from the engine temp sensor doesn't kill the alarm buzzer or the warning light. If I run the engine up to temp the alarm buzzer and light remain on. Put a load on the engine and run for prolonged period and the engine temp gauges show normal operating temps (90ºC)! I haven't been able to find a reset switch to reset the alarm.
Has anyone experience of anything similar?
The boat is a Princess 368 (92) Twin Cummins 6BTA 300's No electronics on the engines.
