conor54
Active Member
Hi All,
My engine is a Perkins Perama M20 which is very very similar to a Volvo MD2020. So similar that the schematics here for the MD2020 are very useful to me.
However....in the Perkins operating instructions the starting procedure is given as:
1. Ensure control lever for gearbox is in neutral position
2. Move throttle lever to full-speed position.
3. Turn key to heat for 20 seconds
4. Turn key to crank (max 20 seconds)
5. When engine fire release key
6. Turn throttle lever down slowly to idle
The Volvo instructions are:
1. Move the control lever to the neutral/idle position.
2. Insert key, turn to pos 1 and check warning lamps
3. Turn key to 2 and heat for 10 seconds
4. Turn key to 3 to start and release when engine fires.
The main difference being that Perkins say start at full throttle and Volvo say start at idle.
In practise I start mine about mid throttle - at idle its a bit to shaky and rough until it has warmed up and full just seems a bit too much.
Any ideas why the difference?
Thanks,
Conor
Thanks,
Conor
