Nasher
Hi all.
Does anyone have any tips for aligning an inboard engine with a shaft?
It’s all very small, and space is tight. The shaft is only 5/8in, the same as the engine output shaft, and the engine a small 4.5HP twin cylinder 2-stroke with a flat mounting plate that has four holes for feet.
I have yet to fabricate or source a flexible drive coupling, and the engine will need some rubber feet between it’s mounting plate and the bearers to reduce vibration and noise through the boat.
Before I start on the coupling, is there anything I can design in that would make my life easier when trying to align the engine and shaft?
One last thought, considering the low power and torque output of the engine driving an @8x7 prop, and that I’d align it as best I could, would it be possible that something as simple as a length of thick wall rubber hose clamped to join both shafts would be sufficient?
Or am I just being daft?
Nasher.
Nasher.
