engine room sound insulation
segaerta
13 Nov 2005
Gent, Belgium
This winter's project is about insulating my engine room. I have a Bav 35 Sport and they are renowned for having NO insulation whatsoever when they leave the factory (cost savings must be somewhere). Engine room walls are off course not perfect rectangles and there's a whole bunch of electricity and other cables and pieces (EVC, shift actuators) attached as well as lots of through-hull pipes (water, fuel, webasto, ventilation). There's also the air inlets that can't be covered up.
Any suggestions how to best approach this ?
I haven't made up my mind yet on the material, could be some led sandwiched (eg vetus, halyard) or 3M Thinsulate.
Not sure what to expect as a result but it cannot be worse than it is now.
Alain
am no expert on this but I believe the materials are quite heavy .. perhaps need to factor this in your considerations if it is likely to add weight to your stern.
I would start with the normal stuff on the underside of hatches, as thick as possible. If this is not enough I would consider thinsulate for the sides a whole engine room in the traditional stuff would add a lot of weight on a sportscruiser I think.
Rob
