Fredd
I sea trialled a boat the other day and need a bit of advice on the engines .
It's a Princess 35 with Cummings 250 , it started on the button from cold , apparently hadn't been run in over a month , ran very smoothly. When we took her out it was force 3 , she accelerated well , up to maximum revs and max speed was 25.2 knots.
The owner said that she would normally achieve 30 knots but she has been in the water since last July so there is probably a lot of fouling on her .
My question is one engine was smoking a lot more than the other , it revved as easy as the other ,sounded fine and didn't seem to have any other problems . It was suggested to me by a friend that it might just be some extra fouling on the prop , but then again it could be a sign of a bigger problem and that as part of the survey there should be a compression test done on the engine .
The engines have a full service history and appear to be well looked after.
Any advice would be appreciated
