Marra
Due to a breakdown of the original Volvo Penta MD31a engine earlier this year we replaced this engine with the Volkswagen 55 SDI.
After lengthy discussions on the options to replace the existing engine:
- recondition the original engine
- replace with a similar Volvo Penta MD31a, 3500 rev. 65 HP
- replace with a VW55 SDI or
- replace with a VW75 SDI
The premise also was that no replacement of the current propeller would be required.
The wharf advised that the VW55 SDI would do the job without any changes /
modifications needed to the propeller. This engine runs at 2500 revolutions and the
gearbox is a HURTH reduction 1:97.
After installation (june 2003) of the engine we suffer from severe cavitation and since then we receive conflicting information from the wharf, the VW-dealer as well as from propeller suppliers.
The current status is:
- the wharf states that the propeller fits this engine, only the current propeller
is worn out. Which is not the case.
- Volkswagen is looking into this but still no solution
- MAXPROP netherlands state that the current propeller 18` will never do the job
a 20` propeller is needed.
- other propeller suppliers mainly state that this type of engine requires a 20`
propeller. One supplier states a 18` propeller and another a 19` propeller.
We would like to learn wether there is some expertise around that reallly can help us out in establishing the true solution for this problem.
Additonal info:
- The engine can/does reach 2400 revolutions
- starting at 1800 - 1900 revolutions we encounter severe cavitation
fuel consumption then is quite high 9 - 10 liters/hour.
HR42: sailboat / sloop
- length over water 10.50 meters
- total length 12.93
- draft 1.85 meters
- beam 3.87 meters
- displacement 11.500 - 13.000
- hullspeed 8
Current propeller:
- MAXPROP 3-blade, type B70 or E70 depending on ctry list
- 18´
- 35 mm shaft
- 1:10 taper
- 80 mm hub
- 10 mm keyway
- 7/8 nut
Final:
Pse take into consideration that this engine can be upgraded to 75HP
by replacing the software at minor cost. Then the engine will run 3500 rev.
Looking forward to any replies.
Additonal info:
- draft 1.85 meters
- beam 3.87 meters
- hullspeed 8
Current propeller:
- 18´
- 35 mm shaft
- 1:10 taper
- 80 mm hub
- 10 mm keyway
- 7/8 nut
Final:
