KevB
A Large beer for anyone who can shed some light. It's driving me crazy.
I have two kad43's which are in excellent condition and serviced less than 15 hours ago.
Here is the problem.... The first couple of trips after the boat went back in the water from it's winter lay up everything was fine, no problems at all. Then a couple of weeks ago on the way to Yarmouth from Chichester (the forum get together), a couple of miles off Yarmouth (sea choppy and third full tank of fuel which had been in since early december and during winter lay-up) the engines started to lose power pulling no more than 3000 rpm. My initial thoughts was that it was just one engine but it's both. I slowed down and had a look around including looking to see if I had picked something up on one of the legs but nothing out of place. Started engines and everything seemed fine for the last part of the journey.
Left Yarmouth a couple of days later and again everything seemed fine until I was approaching chichester harbor when the same happened again.
At this time we were fairly low on fuel so filled up when back in chichester (so full tank of fresh fuel).
Since then the engines wont rev past about 3000rpm when in gear and more often than not wont go past 2600.
These are some facts and what I have tried...
There is no sludge or water in the water separators.
Cleaned secondary fuel filters.
Replaced primary fuel filters (even though the ones on there were less than 15 hrs old).
Checked for blockage on the fuel tank breather pipe incase a Vacuum was being created in the fuel tank.
The engines will run to max revs when in neutral
When first opening throttles in gear the engines rev as normal the boat gets up on the plane as normal, the engine revs are climbing 3500, the boat is leveling out but within about 20 seconds both engines note changes and they start 'hunting' and the revs slowly drop down to anything between 2600 and 3000 rpm.
Anything below 2600 and everything is fine, they sound perfect but go above and they start 'hunting'.
If I slow down to tick over and wait 30 seconds and open the throttles again all the above is repeated, they rev fine then slowly reduce revs.
I've tried each engine individually and they both pull the same amount of revs @ about 2650.
Now here's the weird thing. If I turn sharp to the left the engines revs increase a bit, say about 200rpm. If I turn to the right they decrease by about 500rpm???
I'm totally confused. If it was poor fuel then why would the boat pull away fine then slowly loose revs? the same goes with blocked filters etc....
Each engine has a separate pickup from the fuel tank so the only thing in common with both engines is the tank and the fuel.
Any suggestions welcome.
