lhasa
New Member
Hi all its that Fjord 27 again ! I have a problem at the moment of the engine suddenly accelerating then dropping back again. Its not clutch slip as the boat surges forward, bit of a problem when manouvering! Any ideas?
Hi, no it tends to do it at various throttle settings. I can be cruising steadily when it will suddenly surge for a couple of seconds then drop back, it can then reoccur a few times or perhaps go an hour before happening again. My wife says it has a malevolent entity in charge of the engine ! Does this sound like a plausible explanation !!
I had a similar problem on one of my old perkins 6-354's.
Countless people told me to send the injector pump in to be serviced, but while doing my engine service I replaced the fuel filter and the fuel lift pump, and it has run perfectly ever since.
The filter looked OK, so none the wiser as to whether it was a small air leak, or fuel starvation, but start simple and work your way up is my advice.
