Tradewinds
I wan't to fit an isolation valve in to the existing 15mm copper engine take off pipe for my calorifier. This will enable me to disconnect the flexible silicon connecting pipe (which can be squeezed closed easily enough) without losing a pile of coolant engine side from the open copper pipe.
Is there any reason why I can't use a pushfit fitting such as this one sold by Screwfix?
http://www.screwfix.com/p/conex-cuprofit-isolating-valve-15mm/18814
Instead of one of these compression fittings?
I know there's a difference in price with the compression fitting being cheaper but it's the functionality in practice i'm concerned about.
Will the pushfit give a 100% reliable join in the application I will use it for (on a vibrating hot engine rather than 'static' plumbing pipe runs) or am I better sticking with the tried & tested compression fitting?
TIA
TIA
