D
Deleted User YDKXO
Sorry, not a Volvo problem this time
Three of the bolts fixing the gearbox housing to the port (Sabre 275L) engine in my boat have sheared within as many months, each one individually and in different locations. No shaft alignment problems, no noise/vibration problems and no evidence of over torquing the bolts. Each bolt has sheared cleanly at the interface between the housing and the rear of the engine which tends to suggest housing is trying to rotate relative to the engine rather than move laterally or longtidunally. Starboard engine all OK. Engines about 900hrs operation
Mechanic and I are mystified. What does the panel think?
