WayneS
I am somewhat concerned that our brand new Beta 20Hp engine that we fitted last winter seems to overheat.
Yesterday, on three occasions the alarm went off. The first time was when we were punching the big tide out of Portsmouth so that the throttle at the stop. 20 min after starting the engine and 10 min after pushing it to the stop, the alarm went off. I checked water flow and it was there. How good it was out of the exhaust is diff to say as the exhaust is just below water line when under way. However, I could see water flow in the Vetus strainer.
The pipes from the exchanger to the exhaust, which go via an anti siphon device about 1m away, did not feel hot, in fact they were only mildly warm.
After having the engine off for about 5 min things were OK again.
On my return to port I ran the engine at full throttle again and it alarmed once more.
I have an oil cooler between the strainer and the pump but that should give little resistance.
We are over propped so even at full throttle we only turn 3100 - 3200 RPM.
I have since checked the inlet and it is clear, impeller still looks good, so I am confounded.
Has anyone got any wild ideas?
Cheers
Wayne
Cheers
Wayne
