gunnarsilins
I had this question mailed once before, with no good response, so I´ll give it another try.
My sailing yacht is powered with an Perkins 4.236 diesel, 24 years old with nearly 3000 hours on the clock. The engine is fresh water cooled from the factory. Starts and works perfectly apart from some cooling problems.
When running at cruising speed, appr. 1700 rpm, the temperature gauge shows a little above 90 degrees – perfectly normal.
When going faster or slower temperature changes in proportion to the rpm´s. 2200 rpm = 105 degrees and when idling around 70 degrees.
I have dismantled the entire cooling system, both heat exchangers, exhaust manifold, all tubing, everything. Throughfully cleaned tubestacks and everything else. Checked the thermostate, and put a new one in, just to be sure. The raw water side is dismantled and cleaned as well and the flow is normal.
The only non-original item in the cooling system is a calorifier plugged in to the system.
Anyone got an idea? How can an engine overcool – and undercool at the same time if it´s not the thermostate???
All suggestions appreciated.
