richardjacobs
New Member
I have a 35ft long keel yacht, with a Lister Petter 30hp diesel engine. The engine is rated to deliver maximum power at 3000rpm. We recently discovered that it tops out at 2500rpm under way. The engine revs freely to 3200rpm out of gear. The bottom of the boat is clean. We have a FeatherStream propeller. Unfortunately I don’t know whether anything has changed recently, or when the old fixed propeller was replaced with the FeatherStream, as we didn’t try full throttle. The calculations for the Featherstream came up with the same answer as for the old fixed prop.
We get 6.7kts through the water at 2500rpm, which seems reasonable. When we push the throttle open wider, absolutely nothing happens. No change in noise, no visible smoke.
The local mechanic thinks it is a prop problem. The prop supplier suggests that it’s an engine problem, but can supply a kit to adjust the pitch.
I’m not particularly worried about top speed, but I don’t want to lose power, or ignore a fuel problem that might get worse.
Any suggestions would be appreciated.
