MissFitz
Our engine (a Sea Panther Watermota) has developed a strange problem - when we put it up to full revs, it will go for a minute or so & then suddenly the revs will drop off. If I throttle back & then put revs back on again it works fine - but then does it again a couple of minutes later. If I don't touch the throttle, the revs also come back.
It's not a blocked fuel breather (I've checked) & it's not something round the prop (ditto). It looks like we have a very small diesel leak from the banjo valve at the top of our secondary filter - could it be very small air bubbles that are causing the loss of revs, or would any air stop it stone dead?
Or, er, any other ideas?
All suggestions very gratefully received, thanks.
