Engine Hourmeter connection
nnyerges
11 Nov 2011
Caracas
The hourmeter or hour counter (HM), is for counting the time that an engine is running. Some people, connects the HM to the engine power switch, but it doesn’t ensure that your engine is running. Some people, connects the HM to the engines alternator, but, alternator can fail. So where you really connect the HM to ensure that you are really counting the time that the engine is running?
Alpha22
22 Sep 2003
Cambridgeshire
Use a relay and connect it to the oil pressure light.
Though if my alternator fails, the least of my worries would be a few hours off the hour meter.
VicS
13 Jul 2002
If you connect it to the alternator output it will run all the while the battery isolator switch is closed.
If you connect to the "ignition" switch it will only run while that is on. You dont normally leave that on when the engine is not running. In most cases there would be an alarm sounding if you did .
A relay might not be needed to connect to the oil warning light.
Modern engines with computerised engine management and control systems may need more consideration.
nnyerges
11 Nov 2011
Caracas
Also you can connect it to the fuel pressure switch (positive feed), so you dont need a relay like in the oil pressure switch case
