FullCircle
We have a little Volvo MB2-A saildrive petrol twin that has been rebuilt. Its a sort of a hybrid Honda outboard 6hp actually, with a Volvo name on it.
The issue is that it will start sweetly and run, then after 5 minutes it mysteriously stops, and refuses to start again.
I have:
Tried choke in/out, throttle off/half/full on.
Plugs out and pull engine over to clear flooding
Renewed the plugs (again)
Gapped them
Checked for fuel - wet plugs! - New fuel last week
Tried a direct connection from tank (outboard 3 gallon with bulb)-no joy
Checked carb connections - choke is off, throttle is on idle stop, air intake is clear
Put plug on head to check spark - yep its there
Naughty bit - sprayed a whiff of Bradex in intake - still no start.
This is a CDI engine with a single coil, and the pickups are off the end of the camshaft.
Is it possible there is something that could be breaking down in the electrics after 5 minutes, not to return to normal after an hour?
Anything that a bank of lowish batteries could do in reverse to suck power from coils to spark?
Thoughts and musings would be very welcome. I have the hump with it all today as it has not been a happy year for engines.
Lynn says she doesnt mind me having the hump, but it wont last I am sure.....
Jim
<hr width=100% size=1>Our engine will never wear out - it only runs for 5 mins before packing it on again.
I have:
Gapped them
Jim
