chubby
My Vetus m4.17 has a 10 amp spade fuse on the engine near the relays which presumably protects the ignition circuitry and ? pre heat, which annoyingly blew and engine stopped and couldn't restart: turn the ignition and none of the panel lights responded, managed to drift onto our mooring buoy and investigation showed blown fuse and all seems well after replacement of said fuse but any reason why this should blow? anything to check to prevent it happening again or just replace, keep a few spares and carry on!?
The actual ignition key and also the relays were replaced this year because key sticky and corroded but have done 200 odd miles since with no problems, is it just a one off fuse blow??
thanks for any insight
