doug748
The next question in my series of if's and but's about my new engine:
8mm pipe is specified for the fuel system on this engine (BD722). Whilst I do not mind uprating the leak off pipe, I do not fancy draining the fuel tank, and the rest of the palaver with the primary filter, in sorting out 8mm supply:-
Would 6mm do?
Anyone used 6mm with this motor?
Anyone know the max flow rate that 6mm can support, bearing in mind that the maximum fuel consumption is c 4 litres per hour?
Thanks Brian. (PS: yep, I do know the address of Beta Marine)
Would 6mm do?
