Durcott
Hi Forum folks - hope you had a great weekend.
Mine was a mixture of frustration and embaressment ( - plus I had some trouble on the boat
Long story short - old Honda BF9.9a has had a comprehensive service, and was pronounced 'good to go' on the test tank. (Trustworthy motor guru.)
Then - a boat sale opportunity that fell through meant the motor sitting in its stern 'locker well' installation for three months on the hard, during the winter
Boat launched last week - engine no worky. Fresh fuel etc etc. Suspected water in carb, so drained the bowl, and initially things were good.
Tried a 'motor' test - managed the length of the River Axe - about 5 - 10 mins - with no problem. As soon as I got confident, and found open water in Weston Bay - motor died. So did the wind, hence embarresment.
It's certainly running OK, but it keeps cutting out, and then won't start. Cut out is sudden and fast - an instantly dead motor.
Have tried gravity feed by raising tank well above motor. No difference. Have tried nipping the fuel tube upstream of the primer pump - when I do this there is pressure in the bulb, so I 'know' there is fuel.
There is a reasonably healthy spark. There is something that looks suspicially like moisture droplets on the spark plug surfaces
My suspects at the moment are dodgy fuel pump, or water elsewhere in the system - in-line fuel filter perhaps? But why did I get a reasonably long test run before the cut out?
Has anyone got any sure-fire diagnostic processes for 'water in fuel' or dodgy fuel pump?
Any other suggestions welcome, before I throw the damned thing over the side. (Last service cost a fortune compared to value of motor.)
Kindest regards
Jeff
Kindest regards
Jeff
