Warpa
With the outside of the boat machined and waxed, stern drive cleaned, sealed and waxed i plan on doing the engine after the service and winterisation.
I plan to do it the same as the truck, but will use a hose and not a pressure washer before sealing and dressing all the rubber and plastic. Now am i ok in filling the space below the engine with water and turning on the bilge pump to remove it? I have a manual pump also on the boat if needed, or should i avoid the flowing water and just degrease and use rags to wipe away?
