pmyatt
Friends of ours with a 4 cylinder Solé diesel (marinised Mitsubishi) have just had the engine lifted out for repair because of water in the oil. The problem seems to have come from a set of four blanking plugs between the block and the head; perhaps put in when the engine was converted to a marinised fresh water cooled version? When these plugs corroded through, the fresh and sea water system were able to mix, but this does not explain how the water reached the oil, unless it travelled from the water galleries to an oil gallery at the head/block interface? Additionally, although the heat exchanger tubes were clear, the dismantled heat exchanger body was filled with a soft rust-coloured clay-like deposit.
At a cost of approx. £ 2000, this is all going to be rectified but, it raises a general question; just how much maintenance do people do on their cooling system; do they check block/head anodes regularly, heat exchanger contents, both tubes and body, flush both fresh water and sea water side of cooling systems with de-calcifier, flush with rust inhibitor, etc., etc. I know I have not been doing this - but sure as hell are going to look at it now!!!!!!
