Wakatere
As usual one small job has spawned a couple of larger ones.
The single-lever control is by Vetus; it looks like a Vetus SICO but with a cast handle - I assume that's because it's old - it may be original in which case it's been in the sun rain and salt spray for 48 years.
It now has a number of annoying habits
Is it just trash?
On a related note, the travel if the throttle (it's a Beta 14) is about 3cm but the travel of the cable/lever is 3". Is there some way of limiting the lever travel? I've looked at the installation guide online and I don't see any guidance.
Any suggestions gratefully received.
TIA
Charles
- It squeals when you move it, and spray lubricant doesn't help. I haven't been able to get the lever off to try to get to the insides.
- It's stiff, which makes it hard for the crew to operate and also means there's no "feel" for when the throttle is at the end of its range. This makes it easy to put a lot of stress on the cable bracket at the engine.
- The neutral button no longer moves.
Is it just trash?
TIA
Charles
