mogmog2
These cost a lot of money, presumably at least in part because they are time-consuming to make. For the less sophisticated engine, what differentiates one brand from another - eg Volvo, Beta, Yanmar? I'm looking at a small engine that hasn't got a panel.
AFAICT, You need to know the:
What info you need/want to display
Wiring/ sensor connections
Rev range for the tacho. (Is the tacho pulse usually once per revolution?)
The type of connector plugs for the existing wiring loom/harness
I want revs, hours & oil pressure/water temperature lights as a minimum. If I made my own, I could add guages for the latter. In theory, that is very useful information (over just a critical warning), but in practice, on a yacht where they're not that easy to see, is it worth it?
Anyone made their own or adapted one to their purposes.
Many thanks
Many thanks
