Jungle Jim
Please excuse the lack of technical detail, it's not my boat so I don't know all the make/models of the bits. I'm sort of honorary engineer as the skipper knows less than I do about it.
It's a Bav 36, 2005 model I believe. Friday night we moored up, put on the shore electrics although didn't realise the battery charger was not switched on. Next morning on booting up the instruments the auto pilot screen showed an error, which I believe signified low battery voltage. The Bav has two voltmeters, one registered 13.2 volts, the other 11.2 (don't ask me which battery is connected where). We realised the charger was off so turned it on for the remaining 10 minutes we were moored. The instruments then powered up normally.
On starting the engine after a few seconds at idle we got an intermittent engine alarm and charging light flickering on the engine panel. If we rev the engine it stops, and is fine when motoring.
The fan belt is a toothed belt and seems fine. All alternator connections that I can see are fine. After 2 days normal sailing, motoring and mooring on electric pontoons both batteries now show normal charged levels but we still have the engine issue.
I won't be back on the boat for two weeks and the skipper will probably pay a professional to sort it before then but for my own knowledge I woukd like to understand what is happening. Anyone got any ideas? Is it likely the low battery voltage had something to do with it?
