STATUE
From the Leaving Lymington thread
In real life, if your engine packed up immediately after setting off, would you:
- Continue with your passage
- Return to the pontoon under sail
- Drop anchor and fix engine / get a tow into pontoon
- Do something else
Only last year, right at the very tip of Portland Bill and close in for the inside passage to Weymouth, all engine alarms went off.
Tide would have pushed me up through the passage but a burgeoning F4 would be against.
I knew immediately I needed sea room, singlehanded as I was.
Luckily,I was motor sailing so turned to starboard and shot out into Lyme Bay and the opportunity to go below and locate the problem - which was me !
Out with the kettle, filled up the closed water cooling system and then putting back the pressure cap CORRECTLY THIS TIME !
