Engine Box insulation...
EdEssery
5 Sep 2001
Berks.
I need a piece of Engine box sound insulation 56cm x 56cm x 3cm.
You know the stuff - foam rubber with a coating of silver foil...
Anybody have any ideas where I could get some?
I am based in NE Hants., work in London and the boat is in Southampton.
TIA
Ed
30boat
N/A
26 Oct 2001
Portugal
Plastimo sell silver foil lined foam in half square meter sizes.It is reasonably effective but not as good as the heavier types.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I suggest you don't waste your time with second-quality stuff (apologies to Plastimo, theirs may be very good) I stripped all the old stuff off mine a few years ago, quite a big job, and replaced with the stuff Halyard sell. Made an enormous difference to the noise.
gtmoore
8 Jan 2002
Croydon
I used the Quietlife soundproofing from ASAP and it does make a lot of difference. There are different types depending upon your application.
Gavin
27 May 2002
Re: Halyard - 2 questions
I am thinking of doing the same but have no idea of the cost / surface area?
Which type of Halyard material did you go for?
vyv_cox
coxeng.co.uk
It looks like the 32 mm Sealglass on <A target="_blank" HREF=http://www.halyard.eu.com/products/insulation/insulation2.html>http://www.halyard.eu.com/products/insulation/insulation2.html</A> Bought at my local chandler in Holland a couple of years ago, so sorry cannot recall the cost, which is probably different from UK anyway.
The surface layer is fairly robust, plus I sealed all corners and edges with Sikaflex. Still looks quite tidy.
