BrianLynch
I have recently removed and remounted the engine (a Yanmar 1GM10) from my Trident 24 yacht. I am now having difficulty getting the alignment between my gearbox coupling and the propshaft correct. I appear to have a small amount of movement in the shaft at the cutlass bearing end. However, I had inspected the cutlass bearing before removal and thought it seemed in reasonable nick. Now I am getting play but find it hard to believe it is in the cutlass bearing. I am reluctant to lift out the engine again in order to inspect the cutlass and I am even more reluctant to remove the cutlass from its P bracket mounting as it looks like a horrible job !!! How much play is acceptable or should it be NIL ? Any advices PLEASE !!!!!
