Thistle
I'm shortly going to be installing a replacement inboard diesel engine. The existing bearers will, I think, be suitable but I'll need to move and replace the mounts. Access to the shaft coupling will be very limited, probably requiring a couple of extra joints in each arm. Because the new engine is slightly longer than the original, I doubt if there will be room for a flexible coupling. All suggestions as to how I should best go about aligning the engine will be gratefully received.
Thanks!
Thanks!
