Hi Folks,
I am about to replace the engine mounts on our VP2002 together with the cutlass bearing. The cutlass bearing is housed in P bracket and the shaft runs through a Volvo shaft seal to the coupling at the back of the gearbox. When the coupling is split the shaft and the part of the coupling attached to the shaft tends to sag slightly in the Volvo Shaft seal.
Therefore I would like advice on engine alignment with this arrangement so that the shaft will be properly aligned in the cutless bearing.I intend to do the initial alignment pre launch, with the final adjustments carried out afloat as the hull does flex a small amount.
Many thanks
Rob
Many thanks
Rob
