john_206
New Member
Recently bought a boat that has had its engine replaced (Perkins Perama M30) wich is different than was originally fitted.
The replacement job doesn't look the best in the World and the engine has been bolted to a large make up bracket on each side.
Whenever I try to put on any power from tickover I get really bad vibration almost surely due to misaligned prop.
I want to slacken the mounting bolts and can use the steel girders of the hull to line up the engine in a straight line to the stern tube. But how do I line it up vertically? ie in case the engine is sitting half inch to low or to high?? Is it just try it and see or is there a scientific way?
