GrimND
New Member
Hi everyone.
I have a Stourport 27 running on a Perkins 4108 and an Enfield 130 z drive. everything seems to run fine up to just under 2000 rpm. then I start getting a knocking sound which is coming from my outdrive which happens between 4 and 10 seconds each time, the only way I found to stop the knocking is to drop it back into reverse and back into forward gear. I have tried to adjust my Morse cable so that it is central between gears and it still happens. I have removed the cable and done it manually and it does the same thing when I hit 2000 rpm. If anyone can shed any light on this problem it would be much appreciated. If you require any further info just let me know.
Thanks for reading
Regards, Nigel
Thanks for reading
Regards, Nigel
