Daydream believer
I know the battery question has been done to death on this forum but I still have a query. sorry for the long explanation
I currently have Volvo 2020 MD & 2 AGM 105 amp batteries as starter & domestic. I need more amps so it has been suggested that I just link the 2 batteries in parallel & use them for combined domestic & starter. When the monitor shows them getting low start the engine & charge them up.
This seems risky so as I have a battery charger that will charge 3 batteries I thought of buying a small emergency AGM battery which will be charged up every time I get shore power. But not connected to the rest of the circuitry as the whole lot is a real nightmare of wiring
At first i thought I would then hook this up to the starter on the engine with jump leads if i got into trouble. I even thought i might put it in the engine bay wire it permanently with a switch & just flick the switch on & off to do an emergency start.
The problem is the glow plugs which need to pre heat
The glows have a relay in the wiring and I do not know why
So if i also take 2 wires to the glow plugs as well as the starter & have a 0-1-2 switch will that heat the glows then start the engine if i just move the switch over or will it run a current back through the rest of the wiring & burn the lot out
