alt
Folks,
Further to my other thread, while viewing an S28 on the weekend, I was playing about with the trim tabs....
When using the top white button to bring both port and starboard tabs DOWN, the starboard trim tab was showing a low longer to lower on the LED's, so according to the LED's the tabs are not dropping at equal speeds
The same happens when raising both tabs together, the starboard side is taking a lot longer to raise.
Has anyone had this issue?
The relay's seem to work fine, as when either of the 4 buttons (top, bottom, port, stbd) are pressed, you can hear the 'click' fine and the LED's lighting - just the stbd is a low slower than port
