Eltrim ST trimtab switch repair.
Teddy
12 Aug 2001
Thames non tidal
One of the small switches on my Eltrim ST control unit has failed. Not wanting to spend £175 on a new unit I wondered if anybody has successfully repaired / replaced any of the switches?
I know I could wire in a parallel switch above the panel and connect to the circuit board, but I thought maybe I could remove the c/board, which is held in by the 4 switches, and do the job properly.
Any ideas?
Replaced all four switches on ours got them from RYB in Windsor cost about £2.50 ea.
It is a bit fiddly and you need about 4 hands but worth it for the saving. The switches dont pull out of the panel they are soldered in from underneath, youll need a solder sucker to do a tidy job. Enjoy.
