Eltrim indicator
russ
9 Nov 2009
North East Hampshire
I had set the tabs down to help get the boat to plain then I pressed the tab control pad to return them to the park position the led's on the starboard side then began to constantly flicker. Why?
Port led's are fine.
If they’re QL tabs it sounds like one has jammed/drowned.
as far as I know, when they are flashing, that means they are in operation and moving, or trying to, perhaps in this case. sounds like one may not be working properly. may need some oil, if you're lucky
