Ellen's COG
doris
19 Jun 2001
London
Ellen\'s COG
Can some please explain to me the difference between Ellen's heading and COG. I can't believe that B&Q makes that much leeway. At her speeds there cannot be much current effecting her. Getting difficult to type with ones fingers crossed all the time but it is starting to look as if she has a v. serious chance. Brilliant girl!!
Goodge
13 Jun 2003
Solent
Re: Ellen\'s COG
That's amazing.. by moving the cursor around I found a spot in the Southern Atlantic with variation of 25.52 deg W !
You wouldn't want to ignore that in your calculations would you !
FWB
N/A
29 Feb 2004
Kernow
Re: Ellen\'s COG
I always use true...cant see the point of using a standard compass except when the electrics fail. I imagine Ellen must use true also. Why use mag at all if you've got a readout in true?
iangrant
By the Sea
Re: Ellen\'s COG
I looked the other day - struck me that it will make quite a difference - not really bothered with it recently with the couple of degrees on the S coast. Hence the course to steer question!
Woodentop
20 Nov 2004
Re: Ellen\'s COG
If you get into the far north of Canada it will be 180 degrees.
Not sure exactly where - it keeps moving.
AlexL
24 Jan 2003
East Coast
Re: Ellen\'s COG
Its also a matter of terminology. In the absence of any other information "Heading" is always assumed to be magnetic whilst "Course" is assumed to be True. Obviously one could clarify it differently by saying "A heading of 270(T)" but the above useally applies as standard.
ShipsWoofy
10 Sep 2004
Re: Ellen\'s COG
this can't be correct Shirley!
Since this is not a magnetic compass, or at least it appears to be a direct read from B&Q's electronic instruments.
machurley22
19 Jan 2004
Scotland
Re: Ellen\'s COG
Don't understand your point Woofy. Are you saying that this can't be a magnetic heading (despite the fact that it is labelled as such) since it is electronic?
Dave
ShipsWoofy
10 Sep 2004
Re: Ellen\'s COG
I presumed, electronic compasses although using the Earths magnetic field would compensate for any errors. From your response, I guess this was a bad presumption.
Does this mean you still need a deviation card with a fluxgate?
BrendanS
11 Jun 2002
Tesla in Space
Re: Ellen\'s COG
It depends which model you have really.
Fluxgate compasses are affected by deviation and variation, just like a normal magnetic compass. Most will autocalibrate for deviation, by putting into a calibration mode and sailing in circles.
More advanced models will correct for variation if connected to a suitable gps or plotter
