Ellen/ B&Q Surprising facts
tcm
11 Jan 2002
Caribbean at the moment
I note with interest thesection of the teamellen website called <A target="_blank" HREF=http://www.teamellen.com/ellen.asp?artid=1219#> Surprising facts</A> regarding Ellen's boat. This omits some of the more important facts :
1. Ellen is planning to go around the world in less than 72 days. Which is even less time than it takes to queue up to buy a new B&Q kitchen, order and wait for the gear cos it's never in stock unless it's the really REALY cheap range, assemble it, bodge around the corners and then go back several times to argue the toss about the missing door handles.
2. The weight of the boat is 8.3 tonnes, or about the same as 1660 bags of silavperil coarse grit. However, the bags of grit are usually outside at the back of anyB&Q store, and soaking wet from the rain, so you'd only need 1400ish bags for 8.3 tonnes, and some of them would be split, especially the ones at the bottom of the pile. You'd have to be a total idiot to buy them in bags from B&Q as well - much cheaper from Wickes. Or even better, ring up a grit supplier and get a lorry load delivered.
3. It took 62 paint trays to paint the livery. This is actually a total lie, cos anyone in their right mind would have sprayed the livery, and not used a load of nerks with paint trays, and definitely not the poxy £1.99 B Q ones. Anyway, why throw away a paint tray? Sounds like a load of money wasted. They probably had a massive lunch, and put it down as "paint tray" knowing that the sponsors would say ooh excellent, yes, we sell them so that's ok.
4. 1000 dust masks were used in making the B Q trimaran. Another lie - how could it have been EXACTLY one thousand? I spect they took delivery of 1000 and most of them are in someone's garage.
5. Lots of powertools were used in making B&Q trimaran. Obviously, none of these came from a B Q store cos they'd be rubbish, especially the poxy hole cutters which are absolute junk.
6. The mast on B&Q is slightly bent back. A bit like any piece of wood you might buy from a B&Q store, except that the mast on the boat is actually SUPPOSED to be bent.
7. It you wanted to saw up the hull of the B&Q trimaran to take it home in the car, it would take ages, especially if you went to a B&Q store because there's no woodcutting service with a big electric saw like in Homebase.
8. It would take 60 rolls of B&Q wallpaper to cover the mainsail, provided that you didn't mind the fact that there no hope of the pattern matching between different batches. So, really, this would be a fairly daft thing to do. A bit like drawing lame parallels between a superfast ocean racing trimaran and a chain of suburban DIY shops, i suppose...
ashley
25 Jan 2003
\'d After Dark
They used 60 rolls of wallpaper for the sails!!
no hang-on, maybe i misread that :)
<hr width=100% size=1>A truly wise man never plays leapfrog with a Unicorn
ShipsWoofy
10 Sep 2004
Brilliant, I bet they didn't buy any of the brass screws from the B&Q outlets either.
£1.85 for a bag of 4 when the same cash would buy you 40 from a decent builders merchant. Why is everything bagged in B&Q when most other builders supplies sell buy weight?
<hr width=100% size=1><A target="_blank" HREF=http://www.topcatsail.co.uk>New and updated website</A>
jfm
Jersey/Antibes
Tee hee. I notice the 570m of wiring, some of which is a bit mission critical I spect, was NOT sourced from B+Q. They presumably went to a decent supplier
Come to think of it, if they had got it from BQ, they would have needed 570 connectors, as I dont think BQ sell wire in more than 1m lengths
"The only cooking device is a single burner". That's cos the other kitchen bits they ordered never turned up
Evadne
27 Feb 2003
Hampshire, UK
570m?
As long as they weren't using our order office, or maybe this tri is bigger than I thought?
When we ordered a 12000m cable, some genius in purchasing retyped it in imperial units and it wasn't until they rang up and asked if we really wanted 12000 miles of the stuff that anyone twigged.
It's a well established fact that B&Q sell every type of cable in every length except the ones that you are after.
TwoStroke
25 Sep 2002
Ivybridge, Devon
Bag of 4 - you mean bag of 5. They only bag them in odd numbers so you have to buy another bag when you're one short!
npf1
9 Oct 2004
Oxfordshire
suppose must B&Q then build in their price the cost of sponsoring sailing teams, which IMHO is just fine!
<hr width=100% size=1>Have boat. Will travel. Maybe cruising in 2005 - wanna join me?
