Electronics whizz?
Andrew_Fanner
13 Mar 2002
ked into poverty by children
Further down the rev counter saga I've identified a failed component, a rectifier maked SEL B30C50. Is there such thing as an equivalence catalogue to find a modern version, googling suggests that the component is obsoltere and only to be found by firms with a $300 minimum order.
Failing that, the thing turns up to 12VAC into DC, will pretty much any old thing I can solder in do the job? Electronics (and soldering them) is not my forte:)
savageseadog
19 Jun 2005
It might be a twin schottky diode stack. How do you know it's bust, if it is bust what caused it?
Can you post a pic of it close up?
Andrew_Fanner
13 Mar 2002
The device has no continuity through it and all other wiring is fine. The only other compnents on the pcb are a 1K resiistor and a variable pot, presumably for calibration. Photo this evening. As for why it is dead, no idea beyond anno domini or water ingress, I suspect its 37 years old like the rest of the boat.
mikefleetwood
19 Dec 2005
In my shed
In answer to your original question - I expect pretty much "any old thing" will do. A bridge rectifier rated at 1Amp @ 50V will cost you about 40p from Maplin, etc.
I am guessing your device has 4 terminals, probably marked +, - and two marked with a squiggle (~) or AC. Any cheap replacement will be marked similarly.
If your device has only two terminals then the replacement is even cheaper. A standard rectifier diode 1N4001 should be about 10p. Higher current devices are more expensive, but I doubt you will need it for your rev counter.
I would have thought that a 37 year old unit was unlikely to use shottky diodes. May be germanium or selenium though - both low voltage drop like shottky, but I doubt if this makes any difference if this is part of the power suplly bit. If it is part of the sensor circuit, then I will wait till I've seen the photo to be sure.
Hope this helps.
rogerthebodger
3 Nov 2001
Have a look at this site and do a search for the component number "B30C50" and it looks like they have a branch at
Brandt Limited
69 Great Hampton St
B18 6EW Birmingham
West Midlands, England
misterg
31 Oct 2003
N. Wales
Does it look like this (pdf file)?
If so, it would be a pretty safe bet that a generic replacement would do, and would be worth a try. Guessing a bit, I think the original rectifier would have been 5 amp, 30V (max). Noting your reading of 125v, and because over specifying the voltage rating doesn't do any harm, I would try RS part number 226-5603 which is 6 amp and 400V (£1.55+VAT). [edit] Note that the chamfer on the package is opposite to that on the old datasheet[/edit]
But before you do that - How are you checking for continuity? If you are using a digital meter on its resistance range, then the device may well look like open circuit, even if it is OK. If your meter has a diode test, or continuity range test the rectifier using that. Test from each '~' pin to '+' and '-' pins with the meter leads both ways around. You should get a reading of about 0.6Volts (or continuity) with the leads one way around, and open circuit with them the other way around. A reading of zero is bad.
Andy
Andrew_Fanner
13 Mar 2002
Thanks for the advice everyone. Photos from my fancy Cybershot phone camera won't resolve the component code on the thing but given the suggestions that a generic part should do I'm off to Maplins this evening to get a part from them, given that they are on the route home. My philosophy at present is that the gauge doesn't work, so pretty much nothing I can do will make it worse.
Yup, four connections +, - and 2 x ~.
To follow, Why Semiconductor Devices Fail When Incompetent People Solder Them Without Using Heat Sinks:)
Andrew_Fanner
13 Mar 2002
As promised:
New VDO gauge: most of £200
AQ97 rectifier from Maplins: £0.23
Advice and encouragement from here: priceless.
OK, it was the second 23 pence worth that worked (see above re heatsinks) but I now have both rev counters working and showing the same reading when run off the lathe at minimum speed. To be fitted back to the boat this weekend.
rogerthebodger
3 Nov 2001
Does yoy gauge and sender have a VDO ref number on them as I would like to conpare with the ones I have.
My gauge number is N 02 012 165 on label on side it is 3000 rpm
Thanks in advance
misterg
31 Oct 2003
N. Wales
Just turn the blowlamp down a bit /forums/images/graemlins/grin.gif
Very pleased to hear you got it working.
Andy
Andrew_Fanner
13 Mar 2002
Thanks in advance
Sorry for delay in reply.
Gauge id is 815/22/2 1:2 7.74, these are very obsolete but, as it transpired, very fixable. Per VDO the 1:2 represents somehting that runs from a generator at about half engine speed and the 7.74 is a date code.
HTH.
