Electronic Help..... Raymarine Radar Connector
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
Okay.... Removed my raymarine radar dome from the boat yesterday in prep for fitting a new one up the mast.
Whilst removing the dome I disconnected the cable from the dome and removed a small black rectangle 8 pin connector block so i could pull the cable through the mast. Some how whilst removing the cable i have managed to loose a couple of the pin connectors that fit in the block.
Can anyone point me in the right direction on replacment pins for the block....
Or even give me an idea what the block is called so i can look for replacement parts.
To give you an idea of size the block is 20mm x 15mm x 2.5mm
TIA.
