Sailingsaves
https://youtu.be/Fz2knBNQSqU
The video shows an LED driver from CPC Farnell
http://cpc.farnell.com/pro-elec/gde-30c070z3/led-driver-30w/dp/LA05178
The 7W drivers give a constant 25 Volt output that I kick down to use on LEDs.
The 12W, 22W and 30 W drivers all give a pulsating output voltage. Do you think is normal?
Thanks for any responses.
I have talked to CPC (a company that up until recently I used to recommend). Their tech advisers give conflicting info. The burned out in-line RCD that failed (and 2nd one failed too), cpc said could be dry solder, then try replacing resistor, but over 1 year old so we can do no more than that. They don;t stock it anymore but sell a different one. All Pro elec branded equipment.
